The answer is dependent on the airframe you choose. Based on what you have said though, this is marginal power for even a powered sailplane.
Given a more "ordinary" planform, I think you'll need 8 hp or more. I have a past design that flew well with 3 hp on a 10kg airframe. It would not hover, but climbed fairly well.
Yes if the wingspan of the aircraft is large enough.
Johan Brand > Gary MortimerAugust 20, 2014 at 2:18am
Gary thank you very much. The aircraft diameter is 16cm, length is 1.5m and i am looking to a wingspan length of 2.4m but know that i have this sorted out what type of airfoil do you think would be necessary ? or what should the cord length be? sorry for all the questions but i am sort of new to this.
Flight Controller - 15g
R/C Receiver - 15g
Silver Blade Frame - 150g
4x Motors and ESC - 200g
3S LiPo Battery (1300-1800mah) - 150g
FPV Camera and Transmitter - 50g
Hi Johan,
dennis
Hi Johan, I think you will struggle to lift 20- 25kg with a 2.4m.
If its your first aircraft start small with a 40 size trainer and learn to fly that first and then perhaps head off to something like this http://www.amr-rc.com/products/aircraft/kits-to-be-assembled/airpla...
That should lift a fair old weight and the design work is done for you.
Thankfully these days you can design stuff without cutting wood, some links
http://open.nasa.gov/plan/open-vehicle-sketch-pad-openvsp/
http://www.xflr5.com/xflr5.htm
Cheers
Gary
