Error codes?
So I was flying in loiter, when suddenly my front left motor arm just rapidly dipped, and recovered about half a second later. I quickly put it into stabilize and brought it back safely.
However now just looking at the logs, I don't really see anything that suspicious .. except 2 GPS error codes. I've tried searching online but I don't see any error code listings, so is anyone aware what these 2 error codes mean?
https://dl.dropboxusercontent.com/u/203420/Quadcopter/gpserror.png
EDIT: Upon further investigations, I have a feeling this was related to the GPS not having a good fix before I switched it into loiter:
https://dl.dropboxusercontent.com/u/203420/Quadcopter/gpshdop.png
As you can see, the rapid dip in roll was right after the GPS HDOP dropped dramatically.
So my next question is, is there a way I can have the copter fail a pre-arm check unless it has a solid GPS fix, no matter what flight mode it is in? Seeing as you could just instantly take off in Stabilize, then switch to loiter before it gets a good fix, it makes the GPS pre-arm test a little redundant?
Arducopter version is 3.1.1.
Daniel
