Error in APM Planner 1.2.24 - RATE IMAX values not matching
I have just updated to APM 1.2.24 and at the same time changed my RATE_RLL and RATE_PIT IMAX Values.
They should always be both the same as the lock is ticked and it seems to write the parameter OK.
However if I refresh params, the one I changed to 3.0 for example is read as 0.030 and the other remains as 3.0.
This is confirmed in the Advanced Parameter list as RATE_RLL_IMAX will read 3 and RATE_PIT_IMAX will read 300.
Obvioulsy this is an issue and I have now grounded the Hex :-(
I have attached a screen shot of the issue.
I'm glad I always WRITE and REFRESH to check !!
    there will be a new planner version in 5 or 10 mins
    Steven you are correct. to get around it for now untick the linking. if you change the seperately you wont have any issues.
