Hello,
I have problem with my Mission Planner, some of text boxer are over other or mixed with buttons. There is many errors in display. Can you help me ?
Another question Is there some detailed manual about parameters in MP ? For example what is AZ parameter in waypoint ?
Thanks a lot.
Looks like it is your screen size making the text box and buttons overlap. I would assume they are programmed with a fixed size.
This will give you some info about what arguments are in which column for commands. http://copter.ardupilot.com/wiki/mission-planning-and-analysis/miss.... Column one is always the command. Some commands might only have one or two arguments. Columns 6-7 are lat and long, and 8 is altitude for the waypoint command.
