ESC Beeping continuously after power up copter.
Problem:
  • ESC Beeping continuously after power up copter.
Questions:
  • Does the signal cable connection is loose?
  • is there any other problem that can possibly cause this to happen?
  • Is there any other solution besides tighten the signal cable?
Spec:
Y6B
APM 2.5
Mystery Brushless Motor ESC 30A
Motor A2212/15T
Turnigy Nanotech LiPo Battery 6000 mAh 25-50C 4 Cell 14.8V
Note:
-all signal is connected to APM as well ground cable. no +5V cable is attach to APMs output port.
    Have you calibrated the ESCs and RC?
    • Truly sorry for this late reply, i can see that you have a lot of experience. That is indeed the solution. Thanks a lot. You save my day. :D
