Just finnished my quad. I calibratet the esc's following the manual. but still they say trottle to high when I start.. Any suggestions? They just go beep-beep-beep.......
thaks :D:D One problem fixed :) But its still unstable, suddenly one engien just gives a lot of power. so i cant let it go :( I'll try changine the props. The ones im using now gives a lot of vibration
Did you make sure you do not have any trim on the throttle?
Did you set up the ESC's using the hand held controller from Turnigy?
Did you set up each ESC using the throttle channel on your transmitter?
