ESCs just keep beeping at me.
Hello,
I've recently assembled my 3d robotics hexacopter kit, and I'm trying now to calibrate the ESCs, which are 3d robotics brand.  When I plug in my Lipo, they make the musical note and beep, and the propellers jerk slightly.  And then the beeping continues indefinitely.  Any advice about what I should do?
I tried setting the throttle at 50%, or powering on the APM with the USB, but neither of those things worked.
thanks
    Read the docs on your ESC. The beep error means different things depending on how fast, how many beeps, etc.
    Most likely that is an error code indicating "bad/invalid pwm input" meaning the signal (or lack of signal) on that ESC is not in a valid range. Usually this is a bad connection from the APM to the ESC. Check the wires. Bypass the connection direct to the receiver as a test.
