Hello,
After searching internally and via Google, I cannot seem to find a point to point connection diagram of the external magnetometer addressed for the APM2.5. "An external magnetometer may now be used, if desired, to keep the sensor away from sources of magnetic interference. To use that, cut the trace between the micro-jumpers marked above and attach the external magnetometer to the I2C port. See this page for more info." I am assuming that the connection is to the I2C port and the magnetometer is set to 5V. But confirmation and Signal, VCC, Gnd would be nice to assure nothing blows up.
Thanks for any help.
BR,
Steven
I figured it out....Eagle files are your friends.
