Im having trouble with my fail safe set-up
For the fail safe I have already set-up, the short fail safe is for the plane to circle after 1.5 seconds of communication lost, and the long fail safe is for the plane to RTL after 30 seconds of communication lost. I am wondering what happens if connection is never regained after the long fail safe.
Does the plane loiter until the plane runs out of battery? If so, is there a parameter I can set-up so the plane autonomously terminates after a certain amount of time?
If you're not able to regain connection with the plane it will loiter over the home location after the mission until the battery runs out, whereupon it will descend in it's loiter pattern until it lands/crashes, normally the ESC will eventually cutoff and there should be enough battery for the control surfaces, the battery will probably be damaged though.
If you have telemetry you can setup an autoland, but it's good to practise beforehand. I had to do one at 3am one night in the middle of the African bush when the radio refused to re-bind with the plane when it returned from a mission.
There is no terminate parameter.
iSkyMaster said:
Im using a Pixhawk with Mission Planner as the ground station. I know now that it what Im asking is impossible with the Pixhawk.
