Hey all
i have a problem with my graupner xr 16 ifs receiver. I had to replace my old receiver and now there is a problem with failsafe. When i unplug my receiver the channel 3 drops to 900 (the regular values are between 1103 and 1900) which should lead to fail safe. But when i switch of my radio (for simulating a connection loss) the level only drops to 1103. As this is also the lowest regular throttle value there won't be a failsafe. I know there is something like increasing the travel to 125 or 150 percent but i did never understand when to to this. Would this help with my issue and can someone explain how to do this (before or after remote calibration, before or after esc calibration etc)
thank you so much,
tm
  • Hey all,
    i found the reason for my problem. For the ifs system you will need to teach the values as an extra step. Most other systems save the values while binding the tx/rx. It is documented in the receivers manual ....
    thanks! Andre
