Hi,I bought the Skylark OSD and need to connect it to my FPV system. I did it wrong before and burned out the Fatshark TX. None of the wire connections fit frome the camera to the Skylark OSD or to the TX so I know I need to solder wires to get everything to work. Can someone please explain wire for wire what goes together. Also I don't know if the TX gets power from the OSD once the OSD gets connected to the flight battery or do I connect a separate batter to it via the power inputs it has?Thanks,Hal
That's nice, I would greatly appreciate whatever you have. I drew a diagram of how I think it can work. I would also appreciate it if you can look it over for me just to check to see if it is right.
Thanks,
Hal
Thanks,
Hal
