Feiyu-Tech Gimbal and pixhawk
I'm having trouble getting the Gimbal's tilt control to work with mission planner/pixhawk.
It works fine alone, leveling etc.  When I try to pass through tilt control to RC through the pixhawk it just goes straight down and wont move at all.
I've double checked that my RC input is calibrated and that the connections are right...is there something special I'm missing?  If anyone has used one of these, details on your setup would be very helpful! thank you.
  • No ones successfully used this gimbal?
    • Erik,
      I use a Fieyu tech 3 axis gimbal with no problems.  Did you set up the input and which Aux out is to be used in mission planner?
      David R. Boulanger
