MR60
Feta Cheese and Arducopter
In search for the perfect dome for APM 2x? I found one that also tastes good!
Inside the Athenos Feta Cheese container (992172.02) is not only Feta cheese, but also garlic and herbs.  Emptying this protective shell is a true delight when mixed with fresh greens, tomatoes, and carrots.
Then turn the container upside down (note: you might want to clean it first).  The lid, which snaps to the "cowling" for a NEMA 12 water resistant fit, also contains a perfectly sized raised platform for the APM 2X.  Tear off the pour spout on the lid and there magically appears a drop floor for the wires to escape, leaving the APM 2X on a raised bed surrounded by water drains (note: you need to provide a little support under the raised floor).  Weight?  A whopping low 18 grams. What a find.  Wow!
Need to do maintenance?  Just unsnap the Nema 12 fitted cowling for total access.  The plastic is also crash resistant--strong enough to sacrifice itself in a 30m fall (note: it's tested and certified).  And yes, the plastic is environmentally green/recyclable.
Now if I can just patent this little puppy.
  • MR60
    Photo shows optional application of not using the NEMA 12 lid for a 6 gram weight savings.
