First copter build and issues
Hello
I just built my first copter with the following configuration
Hexa copter
APM 2.6
GPS with on board compass
firmware version is 3.2.1
I have setup and calibrated everything but it keeps on flipping front to bottom
Here is a video
https://www.youtube.com/watch?v=EMDVC7NLvOA&feature=youtu.be
I have check my motor order, the props type for each motor and all shoul be fine
I have checked the motor wirring and rotation and it is fine
I went into ardupilot and ran one motor after the other to check the motor order and rotation and it is fine
I have calibrated the compas and when I check in Ardupilot it is fine.
I have calibrated the ESC and all motor are starting at the same time.
Any idea what I did wrong?
Thanks in advance for any help you can provide
Boris
  • After few week ends struggling, I found what it was. This was due to 2 of the propeller not identical to the other ones (even if they did lok the same).
