Flight Q
I was playing to night with the quad in the kitchen.
Its ok. I'm the Mom here.
The quad has a tendancy to roll fairly quickly once in the air.
I tried several times and its not all ways on the same quadrant.
Any ideas?
  • How do I tell if I have a 1.0 or a 1.4 PCB?
    I only bought it about 6 weeks/2 months ago.
    I haver the unit facing #2. If its a 1.4 that might explain it.
  • Its the mag you twist and roll if I am remembering correctly.
    I did connect the battery when it was on its stand upside down, then rolled it over.
    That might be a problem as well.
  • I tried both stable and acro, but didn't calibrate via the CLI.
    I did set it via the Configureator,, but I'll try the CLI tonight.
    Thanks!
  • Are you in stable or acrobatic mode?
    Have you calibrated you accelerometers in CL mode?  (enter "c", then roll twist, shake, etc...)
