Fly away in AC 3.4.2 and 3.5
Hi guys,
I'm using a pixfalcon on a small quadcopter that we are producing. Since several month this machine flies well.
I was previously flying with 3.4.2, then upgraded to 3.5, and my problem is present on both versions
I got this week an unexpected behavior, which is that :
 - once the throttle is over 0% (1100pwm), in stabilize mode (ex: setting the throttle to 1140) and not increasing the throttle, the motors are spinning faster & faster up to the max power
- in loiter mode : setting the throttle below the middle (1500), the motors are spinning constantly at the minimum speed. Setting the throtthe right over 1500, and the motors are pushing at the maximum thrust.
I've replaced the pixfalcon, tried with default settings, and nothing changed.
I've attached the logs and I would be graceful if anyone could help...
2017-07-27 21-53-06.bin
