Flyaway Logs HELP!
Hi All.. first post
Just tested my newly built quad at my mates place - because he has a large garden surrounded by high trees.. Maiden flight for both me and it - and a great place to test it ........... or so I thought
All was well with my intended low flying test (with a couple of bumpy landings that a little trimming of the controls sorted out), then while (I think) pitching back.. all of a sudden it shot up into the air and seemed to have a mind of it's own not responding to my control - fortunately it landed back on earth after switching into RTL. The controls seemed to work as expected otherwise (yaw, pitch etc.).
Result was a broken leg, gps stick, 3xrotors, 1 motor cable to resolder, 1 GPS power cable snapped at connector, Repairable break to frame.
Still - I was so lucky! and I know it! I was in shock after lol - I've had visions of it going wrong racing through my head picturing what I didn't see Next time I'll appreciate the power of these things and get somewhere more open!
Anyway, I have downloaded the logs - could anyone interpret them for me to give me some sort of clue about what went wrong?  They're attached as a .rar
Also got this out of the APM.....
just got this out of mission planner - still a little unsure of what looks like the problem here...
Log File C:/Program Files (x86)/Mission Planner/logs/QUADROTOR/1/2015-01-17 16-34-29.log
Size (kb) 485.2548828125
No of lines 7186
Duration 0:00:00
Vehicletype ArduCopter
Firmware Version V3.2
Firmware Hash c8e0f3e1
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Autotune = UNKNOWN - No ATUN log data
Test: Balance/Twist = GOOD -
Test: Brownout = GOOD -
Test: Compass = GOOD - No MAG data, unable to test mag_field interference
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERRs found: FS_BATT GPS_GLITCH GPS FS_THR
Test: GPS = FAIL - GPS glitch errors found (1)
Min satellites: 0, Max HDop: 3.68
Test: IMU Mismatch = UNKNOWN - No IMU log data
Test: Parameters = GOOD -
Test: PM = GOOD -
Test: Pitch/Roll = FAIL - Roll (-168.16, line 6975) > maximum lean angle (30.00)
Test: Thrust = GOOD -
Test: VCC = GOOD -
Thanks!
Logs.rar
  • APM Log File Analiser v2.0.0.5
    Log FileName: C:\Program Files (x86)\Mission Planner\logs\QUADROTOR\1\2015-01-17 16-34-29.log
    Ardu Version: V3.2 Build: (c8e0f3e1)
    Ardu Type: ArduCopter
    Hardware: APM2
    HW Free RAM: Not Available
    HW Version:
    Frame Type: X
    No. Motors: 0
    Data Found in APM Log File:-
    GPS, CTUN, PM, CURR, NTUN, MSG, CMD, ATT, MODE, EV, DU32, ERR
    Data NOT Found in APM Log File:-
    IMU, ATUN, ATDE, MOT, OF, MAG, INAV, STRT, D16, DU16, D32, DFLT, PID, CAM, GPS2, IMU2, IMU3, MAG2, MAG3, AHR2, EKF1, EKF2, EKF3, EKF4, TERR, UBX1, UBX2, RCIN, RCOU, BARO, POWR, RAD, SIM
    PARAMETER ISSUES:-
    RTL_LOIT_TIME = 3000
    Warning: Return to Launch Loiter Time is less than 5 seconds (Value in ms)
    TUNE = 0
    Information: CH6 Tuning is Disabled
    WARNING: Curruption Of Parameter Lines Detected!
    WARNING: the Analyzer tried to handle them.
    WARNING: This is a v3.2 firmware issue that has been reported!
    06/01/1980 - 000339: Mode Changed to Stabilize
    06/01/1980 - 000339: Mode Initialised at 0 0 Alt: 0 Spd:0
    06/01/1980 - 000340: Armed
    Limited Data Available - Mode Ignored
    06/01/1980 - 000341: Mode Changed to Stabilize
    06/01/1980 - 000341: Mode Initialised at 0 0 Alt: 0 Spd:0
    06/01/1980 - 000346: APM Information: Home is NOT Set
    06/01/1980 - 000346: Simple Mode is Disabled
    06/01/1980 - 000346: APM Information: RC Pre-Arm checks have been completed.
    06/01/1980 - 000346: APM Information: All Pre-Arm checks have been completed.
    06/01/1980 - 000346: APM Information: USB is NOT Connected.
    06/01/1980 - 000346: Rx Information: CH7 Switch is Low.
    06/01/1980 - 000346: Rx Information: CH7 function: Change to RTL Mode
    06/01/1980 - 000346: Rx Information: CH8 Switch is Centred.
    06/01/1980 - 000346: Rx Information: CH8 function: Disabled
    06/01/1980 - 000346: DU32 Landing Detected.
    06/01/1980 - 000346: APM Information: PWM is present.
    06/01/1980 - 000379: Take Off
    06/01/1980 - 000392: Auto Mode is waiting for Throttle.
    06/01/1980 - 000619: Auto Mode is waiting for Throttle.
    17/01/2015 16:34:45 - 000957: Take Off
    17/01/2015 16:34:45 - 000957: Mode Time Changed to 17/01/2015 16:34:45
    17/01/2015 16:34:47 - 001012: SET_HOME
    17/01/2015 16:34:47 - 001013: Set Home as 55.0126100 -01.4459460 Alt:36.34
    17/01/2015 16:34:47 - 001014: GPS ERROR: GPS lock lost for at least 5 seconds.
    17/01/2015 16:34:47 - 001015: APM Information: Home is Set
    17/01/2015 16:34:47 - 001022: GPS ERROR: GPS lock restored.
    17/01/2015 16:34:49 - 001070: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:34:49 - 001070: I2C Error: Current Value of PM Parameter PM_INSErr is 213
    17/01/2015 16:34:49 - 001071: Auto Mode is waiting for Throttle.
    17/01/2015 16:34:56 - 001248: LAND_COMPLETE_MAYBE
    17/01/2015 16:34:59 - 001342: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:34:59 - 001342: I2C Error: Current Value of PM Parameter PM_INSErr is 211
    17/01/2015 16:35:05 - 001507: Armed
    Alt(m ~ ft) Spd(m/s ~ mph) Dist(km ~ mi) Launch(m ~ ft) GPS-Sats GPS-Hdop Eff(mA/min)
    Max 4 ~ 13 2 ~ 4 0.01 ~ 0.01 10.27 ~ 33.69 6 3.63 N/A
    Avg 0 ~ 0 0 ~ 0 N/A ~ N/A N/A ~ N/A 5 2.58 ~~~
    Min -2 ~ -7 0 ~ 0 N/A ~ N/A 0.13 ~ 0.44 0 0 N/A
    Stabilize Flight Time (Session)= 19 seconds, 0:19
    Stabilize Flight Time (Total)= 19 seconds, 0:19
    WARNING: Less than 9 Satellites was detected during this mode.
    17/01/2015 16:35:05 - 001508: Mode Changed to Stabilize
    17/01/2015 16:35:05 - 001508: Mode Initialised at 55.0125385 -1.445933 Alt: 1.36 Spd:0.5
    17/01/2015 16:35:29 - 001526: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:35:29 - 001526: I2C Error: Current Value of PM Parameter PM_INSErr is 203
    17/01/2015 16:35:29 - 001527: DU32 Landing Detected.
    17/01/2015 16:35:31 - 001582: Auto Mode is waiting for Throttle.
    17/01/2015 16:35:39 - 001799: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:35:39 - 001799: I2C Error: Current Value of PM Parameter PM_INSErr is 199
    17/01/2015 16:35:49 - 002070: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:35:49 - 002070: I2C Error: Current Value of PM Parameter PM_INSErr is 197
    17/01/2015 16:35:59 - 002341: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:35:59 - 002341: I2C Error: Current Value of PM Parameter PM_INSErr is 194
    17/01/2015 16:36:09 - 002613: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:36:09 - 002613: I2C Error: Current Value of PM Parameter PM_INSErr is 192
    17/01/2015 16:36:19 - 002884: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:36:19 - 002884: I2C Error: Current Value of PM Parameter PM_INSErr is 189
    17/01/2015 16:36:29 - 003155: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:36:29 - 003155: I2C Error: Current Value of PM Parameter PM_INSErr is 185
    17/01/2015 16:36:39 - 003426: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:36:39 - 003426: I2C Error: Current Value of PM Parameter PM_INSErr is 182
    17/01/2015 16:36:49 - 003697: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:36:49 - 003697: I2C Error: Current Value of PM Parameter PM_INSErr is 179
    17/01/2015 16:36:59 - 003968: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:36:59 - 003968: I2C Error: Current Value of PM Parameter PM_INSErr is 173
    Max 3 ~ 9 2 ~ 4 0.04 ~ 0.02 12.62 ~ 41.40 6 3.68 N/A
    Avg 0 ~ 0 0 ~ 0 N/A ~ N/A N/A ~ N/A 5 2.90 117.05
    Min 0 ~ 0 0 ~ 0 N/A ~ N/A 1.68 ~ 5.52 5 2.72 N/A
    Stabilize Flight Time (Session)= 122 seconds, 2:02
    Stabilize Flight Time (Total)= 141 seconds, 2:21
    WARNING: A HDop of greater than 2 was detected during this mode.
    17/01/2015 16:37:08 - 004207: Mode Changed to RTL
    17/01/2015 16:37:08 - 004207: Mode Initialised at 55.0127244 -1.4459761 Alt: 2.61 Spd:1.33
    17/01/2015 16:37:08 - 004208: ERROR: Battery Fail Safe Occurred.
    17/01/2015 16:37:09 - 004253: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:37:09 - 004253: I2C Error: Current Value of PM Parameter PM_INSErr is 165
    17/01/2015 16:37:12 - 004365: Rx Information: CH7 Switch is High.
    17/01/2015 16:37:12 - 004365: Rx Information: CH7 function: Change to RTL Mode
    17/01/2015 16:37:19 - 004624: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:37:19 - 004624: I2C Error: Current Value of PM Parameter PM_INSErr is 114
    17/01/2015 16:37:29 - 004997: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:37:29 - 004997: I2C Error: Current Value of PM Parameter PM_INSErr is 67
    17/01/2015 16:37:39 - 005366: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:37:39 - 005366: I2C Error: Current Value of PM Parameter PM_INSErr is 16
    17/01/2015 16:37:43 - 005524: LAND_COMPLETE_MAYBE
    17/01/2015 16:37:44 - 005556: Landed
    Max 16 ~ 52 2 ~ 4 0.03 ~ 0.02 10.54 ~ 34.57 7 2.72 N/A
    Avg 7 ~ 22 0 ~ 0 N/A ~ N/A N/A ~ N/A 6 2.66 ~~~
    Min 0 ~ 0 0 ~ 0 N/A ~ N/A 1.93 ~ 6.32 6 2.47 N/A
    RTL Flight Time (Session)= 36 seconds, 0:36
    RTL Flight Time (Total)= 36 seconds, 0:36
    17/01/2015 16:37:44 - 005559: Armed
    17/01/2015 16:37:44 - 005560: Mode Changed to Stabilize
    17/01/2015 16:37:44 - 005560: Mode Initialised at 55.0126912 -1.4460262 Alt: -0.01 Spd:0.01
    17/01/2015 16:44:37 - 005579: Rx Information: CH7 Switch is Low.
    17/01/2015 16:44:37 - 005579: Rx Information: CH7 function: Change to RTL Mode
    17/01/2015 16:44:37 - 005579: DU32 Landing Detected.
    17/01/2015 16:44:38 - 005608: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:44:38 - 005608: I2C Error: Current Value of PM Parameter PM_INSErr is 158
    17/01/2015 16:44:39 - 005617: Take Off
    17/01/2015 16:44:39 - 005635: Auto Mode is waiting for Throttle.
    17/01/2015 16:44:48 - 005882: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:44:48 - 005882: I2C Error: Current Value of PM Parameter PM_INSErr is 156
    17/01/2015 16:44:58 - 006153: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:44:58 - 006153: I2C Error: Current Value of PM Parameter PM_INSErr is 153
    17/01/2015 16:45:08 - 006424: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:45:08 - 006424: I2C Error: Current Value of PM Parameter PM_INSErr is 150
    Max 1 ~ 3 2 ~ 4 0.01 ~ 0.01 8.83 ~ 28.96 8 2.34 N/A
    Avg 0 ~ 0 0 ~ 0 N/A ~ N/A N/A ~ N/A 7 2.33 ~~~
    Min 0 ~ 0 0 ~ 0 N/A ~ N/A 4.80 ~ 15.73 7 2.26 N/A
    Stabilize Flight Time (Session)= 31 seconds, 0:31
    Stabilize Flight Time (Total)= 172 seconds, 2:52
    17/01/2015 16:45:10 - 006465: Mode Changed to RTL
    17/01/2015 16:45:10 - 006465: Mode Initialised at 55.0127073 -1.4459687 Alt: 0.48 Spd:0.66
    17/01/2015 16:45:10 - 006466: ERROR: Battery Fail Safe Occurred.
    17/01/2015 16:45:15 - 006669: Rx Information: CH7 Switch is High.
    17/01/2015 16:45:15 - 006669: Rx Information: CH7 function: Change to RTL Mode
    17/01/2015 16:45:18 - 006782: I2C Error: At least one I2C error has been detected.
    17/01/2015 16:45:18 - 006782: I2C Error: Current Value of PM Parameter PM_INSErr is 132
    17/01/2015 16:45:22 - 006900: THROTTLE ERROR: Throttle dropped below FS_THR_VALUE meaning likely loss of contact between RX/TX.
    17/01/2015 16:45:22 - 006900: THROTTLE ERROR: Current Distance from Launch is 40.65m ~ 133.35ft
    17/01/2015 16:45:22 - 006900: THROTTLE ERROR: Current Direction of UAV is 83 degrees (0 = north).
    17/01/2015 16:45:22 - 006925: THROTTLE ERROR: Throttle error resolve meaning likely RX/TX contact restored.
    17/01/2015 16:45:22 - 006925: THROTTLE ERROR: Current Distance from Launch is 46.75m ~ 153.38ft
    17/01/2015 16:45:22 - 006925: THROTTLE ERROR: Current Direction of UAV is 73 degrees (0 = north).
    06/01/1980 - 007063: GPS ERROR: GPS Glitch.
    06/01/1980 - 007155: Mode Changed to Stabilize
    06/01/1980 - 007155: Mode Initialised at 0 0 Alt: -1.556087E+07 Spd:0
    06/01/1980 - 007155: Take Off
    06/01/1980 - 007155: Mode Time Changed to 17/01/2015 16:34:45
    06/01/1980 - 007156: Armed
    06/01/1980 - 007157: Mode Changed to Stabilize
    06/01/1980 - 007157: Mode Initialised at 0 0 Alt: -1.556087E+07 Spd:0
    06/01/1980 - 007157: Take Off
    06/01/1980 - 007157: Mode Time Changed to 17/01/2015 16:34:45
    06/01/1980 - 007171: APM Information: Home is NOT Set
    06/01/1980 - 007171: Rx Information: CH7 Switch is Low.
    06/01/1980 - 007171: Rx Information: CH7 function: Change to RTL Mode
    06/01/1980 - 007171: DU32 Landing Detected.
    Overall Flight Summary:
    Max 655 ~ 2148 13 ~ 29 6118.41 ~ 3801.806118252.00 ~ 20073005.28 8 3.68
    Avg 0 ~ 0 0 ~ 0 N/A ~ N/A N/A ~ N/A 6 2.69
    Min 0 ~ 0 0 ~ 0 N/A ~ N/A N/A ~ N/A 7 2.34
    Power Summary:
    Battery(V) Vcc(V) Current(A) Used Cap(mAh) Eff(mA/mim)
    Max 12.23 4.79 19.93 0 N/A
    Avg 0.00 0.00 8.69 N/A ~~~
    Min 9.80 4.67 0.03 N/A N/A
    Overall Flight Time = -1105548101 seconds, -18425802:19
    WARNING: If an APM Current Sensing Power Module is fitted then it is failing to measure current consumption correctly!
    WARNING: You could try calibrating the module: https://www.youtube.com/watch?v=tEA0Or-1n18
    *** Enable IMU logging to view vibration results.
    WARNING: Possible Brown Out Occurred because log ends in a highier that expected altitude of 655.27m
    TOPIC: http://diydrones.com/group/arducopterusergroup/forum/topics/quadcop...
    • and a nice picture.... :)        X marks the landing spot
      3702542469?profile=original
