Flying 2.16
SWEET!  My stock AC frame now seems very stable and yaw problem seems fixed.  This revision really seems noticably more stable.
The only thing I am still fighting is sonar (sensor xl-maxsonar EZ4) pid. With the defaults (.5 .1 .06) unit begins to slowly oscillate up and down +- 3 feet.  I changed  d from .06 to .15 and now unit generally maintains height but varies about a foot. I had it at 3 foot for a couple of minutes and then it dropped to the ground for no good reason one time, but usually stays fairly close to set altitude. I can't do inflight tuning - am I on the right track? any tips on what I should tweak the most?  I am also puzzled about the ch7 switch - should I always leave it on, or just for a second when I enter alt hold, or what?
I was always amazed at how accurate the old Ardupirate code was on this frame - I have seen it adjust 3" to go over a tennis ball!  It is quite a rush to fly over rolling ground at 2 ft high - I really hope it will be possible to do altitude hold while in simple mode for wild videos
Anyway, Great Work!
    Try 2.0.17. Got some good logs to diagnose the PID tunning issues.
