Hello all!
It's been a long time since I've had to deal with R/C and a lot has changed in radios. I bought a pixhawk kit with a PPM encoder and a radio with the flysky fs-x8b reciever. What I'm struggling with, is connecting the flysky reciever to pixhawk...
From what I found, ppm encoders are usually connected to reciever units, but the fs-x8b supposedly has a ppm encoder built-in. That means I can connect the fs-x8b directly to the pixhawk? If so, that just leaves the question of wiring, which I'm also confused on. The fs-x8b has 4 pins: PPW, SBUS, VCC GND. From my understanding, I need a harness that connects SBUS, VCC, GND into the standard SBUS 3pin rc connector on the pixhawk?
Thanks for the help!
  • I've created over 1800 tracks of music and sound effects that you can freely use in your videos. It's all original...all my own work. All I ask is to be credited as indicated on my homepage.
  • Interesting, I'll try that when I get home. Thank you for the information!
  • And... I'm pretty sure in the Pixhawk params you need to tell it to use s-bus... but I could be wrong. Maybe somebody else could help you on that or look in the full params list for that option.
  • The X8R s-bus is horizontal... that is to say the RC servo cable is using the 3 pins laying flat not upright.
  • I have my pixhawk connected to my X8R directly from the X8R s bus to the 'RCIN' on the last set of pins on the Pixhawk. It's sort of confusing you do not connect it to the sbus on the pixhawk.
Abdulatif Tlaib liked Ryan's profile
19 hours ago
DIY Robocars via Twitter
RT @SmallpixelCar: First time at @wsraceways. After tuning @HokuyoUsa lidar signal and camera sensor on @NVIDIAEmbedded, my car was able to…
Sunday
RT @breadcentric: The handy bit about racing with self-driving cars is that one can type while the car is racing. Report from #AWSDeepRacer…
Jun 18
RT @chr1sa: Our Bay Area @DIYRobocars meetup is now at 2,700 members. Next in-person events (in Oakland) are training day on July 17 and…
Jun 18
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Jun 10
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
