Hello all!
It's been a long time since I've had to deal with R/C and a lot has changed in radios. I bought a pixhawk kit with a PPM encoder and a radio with the flysky fs-x8b reciever. What I'm struggling with, is connecting the flysky reciever to pixhawk...
From what I found, ppm encoders are usually connected to reciever units, but the fs-x8b supposedly has a ppm encoder built-in. That means I can connect the fs-x8b directly to the pixhawk? If so, that just leaves the question of wiring, which I'm also confused on. The fs-x8b has 4 pins: PPW, SBUS, VCC GND. From my understanding, I need a harness that connects SBUS, VCC, GND into the standard SBUS 3pin rc connector on the pixhawk?
Thanks for the help!
  • Thanks for the info. I am searching for it online for my friend and I am so glad I found your post. I was actually searching for the https://www.topessaywriting.org/samples/agriculture online because I am writing an essay assignment on agriculture topic and for that I want to read some tips on agriculture topic, that is why I was searching for it online and while searching for it on google search, I found your post link.
    Essays on Agriculture, Free Examples, Topics, Titles, Outlines | TopEssayWriting
    Free essay examples on Agriculture for students looking for paper ideas. Explore topics, summaries, outlines, and samples. Find your inspiration here!
  • I've created over 1800 tracks of music and sound effects that you can freely use in your videos. It's all original...all my own work. All I ask is to be credited as indicated on my homepage. https://spicemoney.win https://paymanager.win https://tumangaonline.win
    Spice Money Login 2021 (Agent and AEPS) - SpiceMoney.win
    Spice Money Login is Spice Digital's money transaction app for consumers. This is a login portal, You can login into the Spice Money Portal.
  • Interesting, I'll try that when I get home. Thank you for the information!
  • And... I'm pretty sure in the Pixhawk params you need to tell it to use s-bus... but I could be wrong. Maybe somebody else could help you on that or look in the full params list for that option.
  • The X8R s-bus is horizontal... that is to say the RC servo cable is using the 3 pins laying flat not upright.
  • I have my pixhawk connected to my X8R directly from the X8R s bus to the 'RCIN' on the last set of pins on the Pixhawk. It's sort of confusing you do not connect it to the sbus on the pixhawk.
