For sale, Tarot Hexacopter
I'm selling the following:
FRAME: Talon Hexcopter (V1.0) Carbon Fiber Frame - 625mm
itemID: 9171000060
Specs:
Weight: 440g (w/out electronics)
Width: 625mm
Motor Bolt Holes: 16/19/25mm
MATERIAL: 3K CARBON FIBER, ALUMINUM MOTOR MOUNTS AND STAINLESS STEEL MOUNTING HARDWARE
Motors:  Turnigy Multistar 2834-800Kv 14Pole Multi-Rotor Outrunner  : qty: 6
Spec:
KV(RPM/V): 800
Lipo cells: 2-4s
Max Watts: 660W
Max. current(10s): 45 amp
No Load Current: 1.6 amp
Intemal Resistance: 0.038 ohm
Number of Poles: 14
Shaft Size: 6mm
Dimensions(Dia.xL): 35 x 54 mm
Bolt Holes Spacing: 25mm
Bolt thread: M3
Connector: 3.5mm Bullet Type Connector
Weight: 195g
 Motor controllers: QTY: 6
Input voltage:DC 6-16.8V(2-4S LiPo)
Running current:30A(Output:  Continuous 30A, Burst 40A up to 10 Secs.)
Size:  36mm (L) * 26mm (W) * 7mm (H).
Weight: 32g.
UBEC: without(OPTO)
Package:
1* 30A ESC
MAIN FLIGHT CONTROL:
Ardupilot : APM 2.5
  • Includes 3-axis gyro, accelerometer and high-performance barometer
  • Onboard 4 MegaByte Dataflash chip for automatic datalogging
  • One of the first open-source autopilot systems to use Invensense's 6 DoF Accelerometer/Gyro MPU-6000.
  • Barometric pressure sensor upgraded to MS5611-01BA03, from Measurement Specialties.
  • Atmel's ATMEGA2560 and ATMEGA32U-2 chips for processing and usb functions respectively.
Manufactured by : 3d Robotics in USA
Propellers:
Material:carbon fiberSize:10 x 4.5Hole: VariableWeight: 6g
Package:clockwise cw x 1counter clockwise ccw x 1
QTY : 3 sets
Video Transmitter and Receiver :
Product Description
Elgae 5.8Ghz 200mW transmitter. This system is Good for up to 500m flying with the supplied antenna. An optional directional antenna can extend range to 1km+. This unit a Includes built-in microphone. The receiver unit has additional AV outputs for video recording while using FPV goggles.
Specifications:
Output impedance: 50Ohm
Output power: 21~23dBm
Channels: 8
Transmitter operating voltage: 7~15VDC / 150mA
Receiver operating voltage: 5VDC
Operating temp: -10~85C
Video bandwidth: 0~8.0MHz
Audio frequency: 6.5MHz
Video input level: 0.8~1.2Vp-p
Video input impedance: 75Ohm
Audio input level: 0.5~2.0Vp-p
Audio input impedance: 10K/Ohm
Weight: 25g
Antenna connector: RP-SMA
Dimensions: 55x26x17mm
Channels
5.8G : 5705,5865,5665,5645,5885,5905,5925,5945MHZ
Gimbal:
DYS BLG3SN 3-Axis Brushless Gimbal Frame Kit with 3 pcs BGM4108-130 Brushless Motors for SONY NEX.  Also comes with a Spektrum DX8 and a DX6, has a dual controller setup, one for the pilot, one for the camera operator.  Comes with turnigy lipo batteries plus a charging station.
Looking for reasonable offers.
