FPV kit for Arducopter
Hello,
I would like to fly FPV with goggles with my Arducopter. I would like to be able to use my GoPro camera as video input (as now the GoPro firmware update allows that..).
However, I am a bit lost with all possible combinations.
My arducopter is controlled via a 2.4GHz radio, and living in Switzerland, only a 5.8 GHz Tx/Rx combination for my FPV is imaginable (or, differently said, is not against law...).
I was thinking about getting a RTF kit, and found the Predator set at Hobbyking (i.e. goggles the FatShark predator set from Hobbyking (http://www.hobbyking.com/hobbyking/store/__20672__Fat_Shark_Predator_RTF_FPV_Headset_System_w_Camera_and_5_8G_TX_.html), but I read that the FOV of the goggle is a bit small (20° only), has anyone experience with this product ? What  range should I expect, 250m or more...or less ?
But then, what is the difference with this kit (http://www.hobbyking.com/hobbyking/store/__15126__FatShark_5_8Ghz_Telemetry_System_Incl_Tx_Rx_.html) ?
Lastly, are there other RTF kits I should consider ?
Thanks to all !
Seb
  • Thanks Geir ! No-one else using a 5.8GHz Fatshark FPV combo with a GoPro ?
    FOV is certainly something I have to consider... Another thing is the allowed Tx power for Switzerland, it seems that max is 25mW.....well...anyone having experience with such limited power ?
  • Funny you should ask this now, I have just received my goggles for the same purpose (the second kit you mention). Waiting for the RCV922 cam though.
    I see that the predator glasses has a FoV of 25 degrees, while the Dominator (if I remember name correctly) has 40 degrees, so that should make a difference. Also the included cam in the Predator set is CMOS which could cause "jelly-effect" on a frame with vibrations. THE RCV 922 cam is CCD and should not do this as it scans the frame all together and not line by line. Otherwise the Predator has head-tracking which seems nice.
    Good luck! (and too me as well :))
    Geir
DIY Robocars via Twitter
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Jun 10
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
RT @circuitlaunch: Last but not least, mystery guest @BostonDynamics Spot took to the track @diyrobocars He enjoyed the #brazilianbbq too 😂…
May 22
RT @SmallpixelCar: Today’s race @circuitlaunch for @diyrobocars with @a1k0n Was busy in the morning and did not get a chance to tune camera…
May 22
RT @a1k0n: This was epic. My car was barely working this morning, had to make a lot of changes and extremely dirty hacks. Post-race analysi…
May 22
DIY Robocars @ Circuit Launch, 3/7/2020 https://twitch.tv/diyrobocars
May 22
