Hi Guys,
My name Fernando Dotta and I have several Rc toys... lol
I`ve started using APM (2.5) couple of weeks ago on my quadcopter (X mode). I`ve assebly following the instruction of the arducopter and check several time if everything was right.
My copter after takeoff stated do crazy movements and then its upside down on ground. I was wondering if the vibration of the motor could do that. I mean the vibration could mass up the sensor/control of the copter.
I`ve not using the foam or floating mount, but im about to do it. So my question is the vibration my problem? Or did I do something else wrong.
Dotta
  • Had the same trouble over the last month. The solution I found was reducing RATE_PIT_P to 0.06
    But could not really fine tune the copter stabilize,loiter,auto…. always bad. I decided to exchange my ESC with SIMONK flashed ones and to use carbon probs . Today I made the first test flight and it works perfect with RATE_PIT_P 0.120 rest default. Even holding altitude in stabilize mode always was difficult but now it works easy. Can easy fly in my backyard 4m x 3 m.
    My conclusion for me is with the right ESC the Quad fly’s perfect…
  • Hello,
    I have a simular problem. Quad , x mode apm 2.0 board.
    It flies perfect for about 20 seconds and then it flips backwards to the ground.
    Every prop is balanced and the Apm sits on a plexi board with vibration dampers from a gyro, the plexiboard is mounted on the frame with MK rubber dampers.
    Any solutions?
    Regards Mikael
    http://board.It/
  • I'm using the following configuration:
    -Talon v2 in X mode
    -APM2.0 with arducopter 2.7
    -NTM 2836 750kv with 11x4.7 props
    -LIPO 3S 3000mah
    -FPV Accessories
    Despite a vibrations issue, it fly very well with the default factory settings.
    I Think you should check your engines rotation direction; and be sure to connect the ESC on the correct outputs:
    Front Left = 3
    Front Right = 1
    Rear Left = 2
    Rear Right = 4
    or maybe X mode vs + mode
  • wats the direction of your APM ? i think its in the wrong direction ;)
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
RT @araffin2: 🏎️ After hours of video editing, I'm happy to share a best of my Twitch videos on learning to race with RL. 🏎️ Each part is…
Oct 13, 2022
