FrSky Taranis X9E 2.4GHz ACCST Transmitter
7175645095?profile=RESIZE_584x
FrSky transmitter X9E 2.4GHz ACCST Transmitter Full CNC Arm with X6R Receiver Carton and Eva Package.The most important aspect for any transmitter is maintaining a rock solid connection with the receiver. FrSky is well known for the frequency hopping ACCST technology taking advantage of the entire 2.4GHz band resulting in excellent range and reliability. FrSky knows many things can affect the connection between Transmitter and receiver so RSSI (receiver signal strength indication) is incorporated into all telemetry receivers. The Taranis transmitter is continually monitoring the reception quality at the aircraft. The Taranis will alert the pilot before signal quality becomes critical. This saves planes and makes the hobby much safer!
Description:
  • Brand Name: FrSky
  • Item Name: ACCST Taranis X9E Transmitter Full CNC Arm with X6R Receiver Carton and Eva Package
  • Number of Channels: Up to 16 channels
  • Operating Voltage Range: 6~15V (2S, 3S Lipos are acceptable)
  • Operating Current: 260mA maximum (both RF module and backlit are on)
  • Operating Temperature: -10~60℃
  • Backlight LCD Screen: 212*64
  • Model Memories: 60 (extendable by SD card)
  • Compatibility: FrSky X series, D series and V8-II series receivers (plus other receivers if an external module is used)
  • Taranis X9E-EU version is only compatible with X series receiver EU version and L series receivers
Features:
  • Quad Ball Bearing Gimbals
  • Receiver Match
  • Audio Speech Outputs (values, alarms, settings, etc.)
  • Antenna Status Detection and Adjustment
  • Real-time Flight Data Logging
  • Switch Numbers Extendable
  • Receiver Signal Strength Indicator (RSSI) Alerts
  • Super Low Latency
  • Smart Port Supported
  • Vibration Alerts
  • Bluetooth
Package Included:
  • 1 x X9E Transmitter
  • 1 x X6R Receiver
  • 1 x EVA Case
