I need the real time GPS coordinates from the AR Drone 2.0 which has the flight recorder in it.And i couldn't find any method to get the values from GPS directly. Is there any way i could get the GPS data from the AR Drone |
Doesn't QGroundControl read the GPS in real time? I believe it logs too, so in theory, you could do another open on that file in read-only mode, which shouldn't be a problem unless QGC opens exclusive, and read the data as it is written.
I've often wondered when some clever person would figure out a driver/utility to plug that Flight Recorder into a PC or laptop USB port and use it directly, or just read any stored telemetry data directly.
I doubt the Android utility exposes anything useful. If they finally get a "Windows" version for the Surface, that might be exploitable.
