Xbees are configured, talking fine via x-ctu. Re did my wiring again taking out osd and connecting directly. I get the following SEE SCREENSHOT. FTDI cable direct to xbee and usb to xbee rx -nothing, fine when connected x bee via usb. WTF?
I keep thinking I am doing something wrong, but really I am not an idiot, surely if this is an issue for me someone else out there must have had these issues... Any help would be much obliged. Can I chop a 4 wire usb cable and connect to APM2 via usb adaptor?
UPDATE- I recieved my new xstream adaptor, and after unbricking everything, All is working again. It has to be the ftdi adaptor I am connecting my OSD, in a few minutes, and after that I am not touching anything. 3rd try is the charm:) Crash and Burn! I will be rewiring power distribution, as I am running too much off one esc/bec, but its working! Thanks Ellison for the tips.
+1 Ellison...
900s It stops on the sys id then cannot connect
Are you using the 900Mhz Xbees? I'm not seeing any issues at all with them here. The 2.4s are a mess, however.
