It's not a new thing that people can't get the pixhawk to work with emax escs.
If someone has any solution to this problem, please post it here.
If there are no solutions, then could it be possible to make a firmware change to allow stuff people have bought to work?
(Pixhawk won't calibrate the Emax escs on boot)
Hi Aldo,
Do you say if remove these two resistors, then emax will be compatible with pixhawk?
Do you test it? do you have any video or something?
thanks
yes, remove those components, one is a capacitor and the other a resistor... after that, arming/working with pixhawk is doable.
I dont have a video, its really and easy fix.
good luck.
I opened mu Emax 4in1 of 30A and it's little differents than yours i don't know recognise those components
Here i attach a photo of mine
Can you help me?
maybe is easier if you contact EMAX support... they might know exactly which ones to remove, with the single one is easier, this one is a bit more complex...
It now obvious that there is a problem on with this Emax 4 in 1 ESC. It seems that it does not work with the Pixhawk. Plenty of people are having this problem.
I am trying to consolidate all the information I found on this problem.
There are other opened posts on the same subject :
http://diydrones.com/forum/topics/getting-pixhawk-to-work-with-emax
http://diydrones.com/forum/topics/emax-simonk-esc-on-pixhawk-runnin...
http://diydrones.com/forum/topics/pixhawk-with-emax-4in1
Most progress have been done here:
http://ardupilot.com/forum/viewtopic.php?f=21&t=5784&sid=1f...
It is very strange since the ESC has the SimonK firmware, and that every other ESC seem to work with the same firmware. It is maybe a modified version.
Anyway, here is my config:
-TX: Frsky Taranis (with latest fw)
-RX: Frsky D8R
-ESC: EMAX 4in1 25Ax4
-Pixhawk FC with GPS (ArduCopter 3.2.1)
-3S 3000 mAh battery
I can indeed calibrate the ESCs when I connect them directly to the radio.
And the Pixhawk doesn't seem to communicate with the ESCs. Somethings happen when I plug some servos to port 5 and 6 (for gimbal), but still, not motor rotation...
I hope this can be solved quickly.
Tony
I took the problem the other way. I asked EMAX why it doesn't work. I wrote them an email and here is their answer:
"The current 4 in 1 ESC 25A doesn't support Pixhawk, we had noticed that and are currently modifying the firmware and doing test so that the new firmware will be compatible with Pixhawk flight controller. We will finish test in around a week. I will keep you posted about it."
So, hopefully, we should have some news next week.
Tony
Any solution after few months? because i can't do anything... I'm think that i will change my emax 4in1 by qbrain...
Did you have any luck on this?
Waiting for the solution? :(
Well, finally.
