I recently came across an issue on my Pixhawk running the latest PX4 firmware (loaded on 6/23/2016) through QGroundControl.
1) Starts off on ground with solid blue (or green if outside and GPS lock).
2) Takes off no problem, but after 10 seconds I get a solid RED LED and a constant beeping.
3) Sometimes it will be RED but then a pattern of beeps.
I see nothing on the net that shows a PX$ solid RED LED.  However, the logs on the SD card show 'Battery Low' and 'Battery Critical'.  The battery is 100% charged, but this happens every time anyway.
So -
1) Can anyone confirm what SOLID RED means?
2) Has anyone seen this issue lately?
3) Is it the battery, a config issue, or the Pixhawk that causes this issue?
Thanks for any experience or insight!
Derek
  • It seems my battery optimization settings in QGC were incorrect, causing a battery low / critical warning.  I saw this in the log file on the SD card.  I messed around with those setting and the RED LED and beeping went away.
    Now - I don't know what the correct settings, or nominal settings should be, so I am not confident that a warning will trigger at the appropriate time now...  but at least I was able to find the settings that affected it.
