I'm planning a "follow me" scene at 3m altitude, down a relatively 'tight' and twisting road with trees etc - I think it should be ok. Only time will tell though! :-)
3D pictures (movies) are good when you have at least 2-3 and more separated layers (the closer should be at few meters), in order to have a good 3D effect.
If you use to fly at some altitude, you will not have any close layer, except if you fly inside a forest for instance. You will have closer trees and further trees (on different layers) and this can give you a good 3D effect.
If you fly above a flat surface like a lake, will be hard to see any 3D effect.
When in air, the closest layer will be at hundred meters and I don't believe you will see a good 3D effect.
It is like trying to see a 3D effect when looking to a wall.
Ok, the main issue with this looks to be weight and width. 130mm wide is tight in a lot of gimbals, and it's an extra 150gm at least for the extra camera and the additional weight of the case.
Still...it's promising...
