GOPRO Frustrations
Im battling to get my gopro to work on the av out, it is correctly wired, cut yellow plug off shield to ground wire to video in on tx, I have other leads for different cameras used on the same tx and they work fine, Started off using wifi which is a complete waste of time, i have downloaded the latest software and checked for updates but there arent any, when i plug it in and go to the play symbol in the menu it freezes and nothing happens, no video just a dark screen. Does  Anyone out there know what i can try next, much appreciate any help.
  • Hi, well I had AV Out work on various GoPros, but can you tell us which model GoPro you are trying with (they vary a lot on if and how AV out works), and how does that cable look that you are trying to use? Which connector on the camera do you use, do you have a schematic? Tested the cable with an ohmmeter? Tested with a direct connection to a display without a radio link?
    Regards
    Soren
