RT @chr1sa: The next @DIYRobocars virtual AI race is tomorrow morn at 9:00am PT. You can watch live on Twitch
https://www.meetup.com/DIYRobocars/events/275268196/
New version of Intel OpenBot! This resolves many of the issues with the first version, including a much smoother tr… https://twitter.com/i/web/status/1352395636369313798
RT @Heavy02011: @diyrobocars : A Home-brew computer club* for Connected Autonomous Driving on Jan 23rd, 2021 https://www.meetup.com/Connected-Autonomous-Driving/events/275728684/ #Meetu…
RT @Heavy02011: @diyrobocars Autonomous Driving Assembly at #rC3. join us at https://rc3.world/rc3/assembly/diyrobocars-f1tenth/ @f1tenth @DAVGtech @DWalmroth…
RT @chr1sa: New car designs coming for our next @DIYRobocars @donkey_car virtual race on the 23rd. Choose any one you want at race time
Le…
RT @RoboticMasters: Thanks to @EllerbachMaxime and the Sydney Uni Capstone Students the @donkey_car @diyrobocars simulator is getting a ma…
Do you live near the Florida Pan-handle? I ask because that's where I live, and I am just finishing up my own UGV, SAGAR.
More here: http://www.billporter.info/?cat=11
To answer you last question, yes, you need a magnetic compass. You will also need at least a PD control system
Feel free to send me a message and I'll send you an email if you want some further help on your project.
here is the code all together.
// A simple sketch to read GPS data and parse the $GPRMC string
// see http://www.ladyada.net/make/gpsshield for more info
#include
NewSoftSerial mySerial = NewSoftSerial(0, 1);
#define powerpin 4
#define GPSRATE 4800
//#define GPSRATE 38400
// GPS parser for 406a
#define BUFFSIZ 90 // plenty big
char buffer[BUFFSIZ];
char *parseptr;
char buffidx;
uint8_t hour, minute, second, year, month, date;
uint32_t latitude, longitude;
uint8_t groundspeed, trackangle;
char latdir, longdir;
char status;
void setup()
if (powerpin) {
pinMode(powerpin, OUTPUT);
pinMode(13, OUTPUT);
Serial.begin(GPSRATE);
mySerial.begin(GPSRATE);
// prints title with ending line break
Serial.println("GPS parser");
digitalWrite(powerpin, LOW); // pull low to turn on!
void loop()
uint32_t tmp;
Serial.print("\n\rread: ");
readline();
// check if $GPRMC (global positioning fixed data)
if (strncmp(buffer, "$GPRMC",6) == 0) {
// hhmmss time data
parseptr = buffer+7;
tmp = parsedecimal(parseptr);
hour = tmp / 10000;
minute = (tmp / 100) % 100;
second = tmp % 100;
parseptr = strchr(parseptr, ',') + 1;
status = parseptr[0];
parseptr += 2;
// grab latitude & long data
// latitude
latitude = parsedecimal(parseptr);
if (latitude != 0) {
latitude *= 10000;
parseptr = strchr(parseptr, '.')+1;
latitude += parsedecimal(parseptr);
// read latitude N/S data
if (parseptr[0] != ',') {
latdir = parseptr[0];
//Serial.println(latdir);
// longitude
parseptr = strchr(parseptr, ',')+1;
longitude = parsedecimal(parseptr);
if (longitude != 0) {
longitude *= 10000;
longitude += parsedecimal(parseptr);
// read longitude E/W data
longdir = parseptr[0];
// groundspeed
groundspeed = parsedecimal(parseptr);
// track angle
trackangle = parsedecimal(parseptr);
// date
date = tmp / 10000;
month = (tmp / 100) % 100;
year = tmp % 100;
Serial.print("\nTime: ");
Serial.print(hour, DEC); Serial.print(':');
Serial.print(minute, DEC); Serial.print(':');
Serial.println(second, DEC);
Serial.print("Date: ");
Serial.print(month, DEC); Serial.print('/');
Serial.print(date, DEC); Serial.print('/');
Serial.println(year, DEC);
Serial.print("Lat: ");
if (latdir == 'N')
Serial.print('+');
else if (latdir == 'S')
Serial.print('-');
Serial.print(latitude/10000000, DEC); Serial.print('\°', BYTE); Serial.print(' ');
Serial.print((latitude/10000)%100, DEC); Serial.print('\''); Serial.print(' ');
Serial.print((latitude%10000)*6/1000, DEC); Serial.print('.');
Serial.print(((latitude%10000)*6/10)%100, DEC); Serial.println('"');
float flat1;
Serial.println(flat1);
Serial.print("Long: ");
if (longdir == 'E')
Serial.print('+');
else if (longdir == 'W')
Serial.print('-');
Serial.print(longitude/10000000, DEC); Serial.print('\°', BYTE); Serial.print(' ');
Serial.print((longitude/10000)%100, DEC); Serial.print('\''); Serial.print(' ');
Serial.print((longitude%10000)*6/1000, DEC); Serial.print('.');
Serial.print(((longitude%10000)*6/10)%100, DEC); Serial.println('"');
float flon1;
flat1=latitude*10E-7; //move the decimal
float flat2=28.323805;
flon1=longitude*10E-7; // move the decimal
flon1=flon1*-1; //make longitude negative for my area
Serial.println(flon1);
float flon2=-82.267417;
float dist_calc=0;
float dist_calc2=0;
float diflat=0;
float diflon=0;
//I've to spplit all the calculation in several steps. If i try to do it in a si
//ngle line the arduino will explode.
diflat=radians(flat2-flat1);
flat1=radians(flat1);
flat2=radians(flat2);
diflon=radians((flon2)-(flon1));
dist_calc = (sin(diflat/2.0)*sin(diflat/2.0));
dist_calc2= cos(flat1);
dist_calc2*=cos(flat2);
dist_calc2*=sin(diflon/2.0);
dist_calc +=dist_calc2;
dist_calc=(2*atan2(sqrt(dist_calc),sqrt(1.0-dist_calc)));
dist_calc*=6371000.0; //Converting to meters
Serial.println(dist_calc); // this gets some crazy big number for a point close to me
delay(500);
//Serial.println(buffer);
uint32_t parsedecimal(char *str) {
uint32_t d = 0;
while (str[0] != 0) {
if ((str[0] > '9') || (str[0] < '0'))
return d;
d *= 10;
d += str[0] - '0';
str++;
return d;
void readline(void) {
char c;
buffidx = 0; // start at begninning
while (1) {
c=mySerial.read();
if (c == -1)
continue;
Serial.print(c);
if (c == '\n')
continue;
if ((buffidx == BUFFSIZ-1) || (c == '\r')) {
buffer[buffidx] = 0;
return;
buffer[buffidx++]= c;
