Mediatek 3318 module can easily fix lock while indoor
via gps mini but by default its update rate is 1hz@9600 baud rate.so it cannot be detected by apm planner.
So how can i update its firmware?
I do not think that tech support will help you with a module that they do not sell.
Is it even possible to update the firmware on this module? Is it possible for this module to have a higher update rate?
Perhaps you should contact the people from which you purchased this unit.
