Hi,which is the best (simple) tool to convert NMEA files from a GPS tracker to Kml files?I'm searching for something which permit to select start and end wp etc.Thanks,Ric
Well done great find. I'm having problems converting txt. files in GPS2KML have to convert it to gpx first in GPSBabel but otherwise it works grate with GGA & RMC strings only. --- what else do you need!
Hi Ric,
try http://www.gpsbabel.org
It converts literally every format into every other format and can also apply some filters while doing so.
Jan
If i have 2 kml files
how do i display path A and path B on the same screen for comparison
Ric
