I bought MediaTek MT3329 GPS V2.0 with my "APM 2.5 + set" from 3D Robotics. After setting up the mission planner, i kept getting GPS No Fix error message in the console. How can i fix this ?
Are you testing the GPS indoors or outdoors? The MediaTek V2 should get a 3D lock indoors, at least mine does. The GPS blue led should flash until a 3D lock is obtained and then go solid.
Does the GPS test okay when you use the CLI GPS test when in the terminal mode? That way you can be sure that the APM and the GPS are communicating with each other. If not, then that may be your problem.
@Sumit,
TCIII ArduRover2 Developer
