Griflion M8--Surveying and Mapping Expert
MMC Griflion M8 is a vertical take-off and landing (VTOL) fixed-wing UAV with the V-shape tail that is made of carbon composite material. Griflion M8 is capable of long-distance cruise flying and features long duration time, fast cruising speed, and high working efficiency, etc. Griflion M8 is compatible with the orthographic camera, the oblique camera, zoom camera and electro-optical pod to run a high precision surveying and mapping or patrol mission.
yvWZ2th.png?profile=RESIZE_710x
Highlights
1.Robust Airframe
Its UAV body is made of carbon fiber and composite material to make sure the structure solid yet body lightest.
 2.VTOL Anywhere
One-key to set automatic vertical takeoff and landing in the multi-rotor mode makes the UAV available for different takeoff sites as it switches to fixed-wing mode automatically after takeoff.
3.For Long Flight Time Missions
VTOL and horizontal fly are using a different pair of batteries to avoid the risk of limited flight time and low battery in VTOL mode and empowers the UAV enough flight time to perform a task.
4.200km-Flight Distance
Pairing different batteries with cameras, its maximum flight distance could increase to 200 km and its single task area could reach over 10km²for land surveying and mapping.
5. 24 Megapixel Camera
The camera adopts a big size 24 Megapixel sensor that helps you capture a high-quality image that misses not even a small detail.
6. RTK/PPK Centimeter-Accurate Position
Griflion8 supports RTK as well as PPK backward difference for high-precision centimeter-accurate take-off and landing.
7. High Stability
It comes with dual antenna orientation, triple redundancy compass and double redundancy GPS positioning for improved stability in flight.
8.Auto Flight with Route Memory
With automatic flight and route planning function, it is easy to operate with the ground station. Even occasionally disconnected, it retrieves route memory to continue the flight.
Applications
Environmental Monitoring
Energy and Power
Specification
Model     Griflion M8
Takeoff and Landing Type     VTOL
Body Material                Carbon Fiber and Composite Material
Wingspan/Body Length       2500mm/1486mm
Net Weight                   5.5kg
Max. Takeoff Weight          12kg
Max. Payload Weight         1.5kg
Max. Climb Speed            6m/s
Efficiency Cruise Speed       22m/s
Max. Flight Speed             35m/s
Flight Time                    150min
Max. Flight Distance            200km
Control Radius                 15km
Max. Altitude AMSL             5000m
VTOL Switch Altitude            120m
Positioning Accuracy            1cm±1ppm
Positioning System            RTK+PPK
RTK/PPK Update Frequency             100Hz
OthersAuto               Takeoff and Landing, Autopilot, The Black Box Function
Drone Assemble Time          5min (by a single operator)
Drone Disassemble Time             10min (by a single operator)
Max. Wind Resistance             12m/s
Working Temperature            -20~60℃
IP Level                        IP56
