Ground station antenna placement
I am currently building an antenna tracker using xbees/arduino, and would like to put all 3 of my antennas on one board. I have 900mhz xbee pro 100mw, 2.4ghz TX 1000mw, and a 1.3ghz vRX at 1500mw. Now as you can see on the picture i have them spaced about an inch apart and am wondering if this will cause interference since they are so close to each other. I have yet to try this setup and would like this to work, or something similar so i only need 1 pan/tilt tracking on the ground. Thank you!
  • Thanks for the reply, ill give it a try!
  • It should not be a problem, the bands are far apart. I may worry about RF interference in the circuits, though those are usually shielded.
