Hi every body,I'm going to build a quad copter and right now I'm studying the control alternatives.I'm going to build the control system (micro controlled) but i have some doubts:- Is really a difference between a Gyroscope and a 3 axis accelerometer? Due to my ignorance I think that is enough with an accelerometer readings to stabilize and control the motors speeds to do the movement that the controller wants to do.- I thinking to include a magnetic compass, i have seen magnetic field sensing chips to implement the compass, with this sensor can I calculate as well the position respect the earth? or isn't precise enoughAt last but not least, I thinking to mount a little wireless access point (the fonera, that works with an embedded Linux easy to program) to read the telemetry data and send complex orders to the controller (in future stages of the project), what is the best / commonly used solution to link the UAV to a computer? What range provides it?Thank you very much,Regards,Chema
The only way I could see the accels actually functioning is if we're reaching steady state a lot sooner than you think. Experimentally, giving a quad a 5 degree tilt seems to have it going at a pretty steady speed after the initial acceleration. I do realize how the forces involved work but perhaps since only a small portion of the thrust is going to lateral movement, and there's so much turbulence it can steady out quite low.
You're right. It's counter-intuitive (at least for me), but the accels do always cancel out. At least so long as you're maintaining altitude.
Odd that so many projects use accels and no one I've read about has noticed that it shows nothing. Makes me feel like we're still missing something, but I'll admit your logic does add up.
Gyros give good short term readings but drift over time. Accels give useless short term readings, but can be filtered to give a reading that doesnt drift over time. The accels are used to correct for the gyros. Gyros only is an option, but only if you plan to be flying manually, and compensate for the sensor drift yourself.
Magnetometers can run into problems with all the current going to the motors. As they rev up and down you might see as much as a 15 or 20 degree shift in angle. There may be solutions to this...
Check out Xbee for wireless data. Their modules are pretty cheap and the better ones can go a mile or more.
Thanks for the help (and sorry for not reading the FAQ), and after reading your answer and the FAQ I also think that I must use the gyros...
I'll take a look to the TTL modems, but my idea of use the AP is because I can write a C program in the fonera that uses The serial port or even an I2C bus, and control from my PC with a web browser. I shouldn't deal with the TCP/IP directly...
What range can offer the TTL modems?
Thanks!
Regards!
You can use a precise (+-2cm) Indoor "GPS": http://marvelmind.com/.
Here is a couple of demos:
Just a thought...
Thanks!
Regards!
