I just tried to configure the Mid Throttle value, than everything went wrong :(
The following happened:
I tried to increase the value of Mid Throttle via the APM Planner, I updated the param disconnected from the APM and disconnected the USB cable too. After this I can't armed the motors. I tried to set back the param (though it was in the right range, I mod from 500 -> 600), same issue. It was also strange that I can't connect to the telemetry.
Than I reinstalled the firmware and did the calibrations, than I realized that I could arm the motors and they are spinning if the USB cable connected.
Another finding that in case the USB cable wasn't connected and the telemetry connected the yellow led (B) is flashing and the ESCs did not beep long (after the 3 short beep for the 3S LIPO). If I removed the telemetry cable they're beeping correctly but still not able to arm the motors without the USB connected :(
If USB connected and motors are armable I still not able to connect to the telemetry.
I already started to think that maybe the dual LIPOs killed the power board, but I already did about 10-15 ~25min flights as test without problem. Like I did this morning too.
HW Configuration:
SW Configuration:
Any help/suggestion are welcome!
Tags:
It's possible that telemetry is not working if some of the parameters were updated. Not an indication of hardware failure.
Need to check all the parameters.
But if I just reinstalled the firmware this shouldn't be the case isn't it?
Ok I did some measurement, this may helps:
So on the ESC "side" I measure no voltage drop if the USB is not connected, but here's a video how it behaves:
APM blinking yellow till the USB get connected, than the motors can be armed. But I'm experiencing woltage drop on other power pins of the APM:
USB not connected 3.18V :
USB connected 4.92V:
So I assume it's something power related, may the APM could not boot up?
Ok I realized what's the issue:
I baked the power board and it seem the fuse 500mA Fuse on the board.
The first one could cause the low voltage -> APM won't boot up
The second one cause the it didn't get the voltage from the ESC BEC -> APM won't boot up
When I jumper the + from the output to one of the analog input:
it boot up correctly, and the telemetry also works fine. But this is just a work-a-round the problem exist.
I'll have to disassemble the drone and check if my hint's are right or not.
So one root cause could be that I didn't removed the JP1 so the high and low power circuit didn't separated. (Am I right?)
Thanks the answers in advance
And I also found a related article
45 members
1472 members
282 members
470 members
57 members
Powered by
