How do I back up MTK 3329 firmware it? I can download to upgrade the software, but there is no backup
http://code.google.com/p/ardupilot/wiki/MediaTek
May I ask who can provide the following MT3329 5HZ 38400 firmware it? Thank you very much。
I have upgraded the firmware provided above, but only 1hz refresh rate, a bit slow for FPV. I can support OSD to 5HZ, hope someone can provide what MT3329 5HZ 38400 firmware
If a friend needed MT3318 command line, I am here to provide you with
Thank you for your reply
I know that you can use the command update rate is to be changed. But I can only use
$PMTK300,200,0,0,0,0*2F<CR><LF>
5HZ to change the refresh rate, this method is not permanent storage.
Can not use
$PMTK390,0,5,9600,0,1,0,0,0,1,0,0,0,0,9600*3D<CR> <LF>.
He prompts
$PMTK001,390,2*3B
Means the command is correct, but can not perform
Is there a good refresh rate and the baud rate to directly modify the firmware to download it?
