Help with RCTimer 915MHz Radio Setup
So I purchased the full Fixhawk kit from RCTimer and I am almost done with setting it up. Aside from the frame, motors, ESC's, and battery these components are what I ordered.
  • Fixhawk
  • 915MHz Radio Telemetry Kit
  • RCTimer U-Blox LEA-6H GPS & MAG V2
  • Fixhawk I2C Splitter
The last hiccup I have run into is getting the 915MHz radios to work together. I followed the incredibly out-of-date instructions in their product info section to no avail (RCTimer 915MHz Radios). Has anybody else successfully configured these radios either through 3DR's Mission Planner or any other means?
  • 3702067503?profile=originalSo as you can see through the 3DR Radio Config tool, I can get my two receivers to communicate but the issue is when I use Mission Planner. I have the correct COM port and Baud rate set, I can see the solid green lights on both, flashes on the red LED as they are trying to communicate, but still no MP connection. Anybody else have this issue?
    https://storage.ning.com/topology/rest/1.0/file/get/3702067503?profile=original
