I have tried Mission Planner 1.1.27 and 1.1.31 and am getting similar results. I am using Xplane 10 and APM v1.
The link seems fine, data is populated in the simulation screen, I can fly the plane, I think stabilize is trying to work (it has Ardupilot Output numbers that change, the PID is just way off) but the "Flight Data" and "Flight Planner" tabs do nothing.
So when I try to set my current location with the Home Location button, it says "...commect to your APM and wait for GPS lock." and the Flight Data screen looks just like it does when nothing is connected.
Any ideas what is going on here?
  • in my simulation with Xplane 9 the mission planner attitude data is not the same with the Xplane 9,if i change Xplane9 to Xplane10,mission planner attitude data do not change any more, anybody know why?
    Xplane 10 should now be working 100 %. remeber to tick the box though.
    "but the "Flight Data" and "Flight Planner" tabs do nothing". What does that mean? The tabs do nothing? There's nothing in those tabs? They work fine, but the data isn't changing?
    If you're not getting data back from Xplane you need to check your Xplane settings with the instructions in the manual.
    What version of the ArduPlane code are you using?
