I've got a bixler and have installed an APM1.4 with v2.40, GPS, magnetometer, xbee and everything is working great but in stable mode it climbs at like a 20 degree angle. In manual it's ok. I'm sure this is because when I did the manual level (I'm not using the auto level at each boot) I just put it on the ground and made sure the wings were level but apparently the pitch is not level by just sitting it on level ground.
How should I level it before pressing the leveling command in the planner? It seems I would need to raise the tail up about an inch off the ground but is that normally necessary? I know the elevator trim is ok because in manual mode it's all trimmed out but when I switch to stable it thinks it's pitched down so gives some up elevator.
So what is the proper way to find the level point?
