From http://ardupilot.org/copter/docs/parameters.html
MOT_PWM_MIN: PWM output miniumum
This sets the min PWM output value that will ever be output to the motors, 0 = use input RC3_MIN
| Range |
| 0 - 2000 |
MOT_PWM_MAX: PWM output maximum
This sets the max PWM value that will ever be output to the motors, 0 = use input RC3_MAX
| Range |
| 0 - 2000 |
But I cannot find these parameters in the full parameter list in arducopter 3.3.3?
I ask because I see the servo_out PWM to the motors sometimes hitting a lower "limit" of 1148, and they never seem to exceed 1850 or so. I'm trying to understand how these limits/ranges are established?
Ha yes I have the same issue 1848 is the max output by the fc,Did you find a fix other than calibrating the esc's?
