Ok,After bad ESC, bad GPS, and bad APM my drones is almost ready for flight. Still waiting for GPS replacement.While I am waiting I decided to try and fly this beast but have questions.Mostly how does a quad steer left and right? When I push left and right on the stick it seems to do nothing. When I give it enough juice to get off the ground it just heads left, then it flips over.What happens when you push left or right on the stick?
You should feel it tilt when you push left or right on the stick (holding it firmly in your hand, with lots of prop clearance). If it doesn't, you haven't set it up right. Make sure you've done the full MP config (including RC config), done the motors test in the CLI and otherwise checked and rechecked all your setup.
Thank you for the info. Curious when it is set up properly how does it steer left, right, front, back?
