How to add a library?
I have a C++ class (header and implementation) that I have added to the libraries directory (in AP_foo subdirectory) and I want to use this library from within some modifications I will make to some of the .pde files.
I have an #include <foo.h> in ArduPlane.pde. However the new lib doesn't get added to the include path in compilation, so it fails because of a missing file. Unless I do what?
I don't know this cmake thing too well. I have tried to fire a cmake in the root ardupilot dir, and it prints nicely "Generating Arduino XXX library" for all libraries I can think of except mine. I cannot find a list of the library names getting generated. I suppose generation includes having the libraries generated added to (a superset of) includes for compilation..?
Does somebody know what I can go to get cmake - as used in Ardupilot - to recognize my library or its use?
Regards
Soren
  • Hi,
    Well I knew C++ for some time but not Arduino....
    Apparently one just has to make a dir named Foo in ardupilot/libaries/ and then put at least Foo.cpp and Foo.h in that dir. Foo is any name of course.
    Create ardupilot/README.txt if not existing. Go to ardupilot/build (or create it if not existing). Run cmake ../ArduPlane . The lib should then be put on the include path for ArduPlane if I understood this right..
    Nothing is compiled at this stage. Only makefiles generated.
    Regards
    Soren
