  • Hi,
    Would someone help me to use RFD900 for first time. This is what I have doen/seen so far:
    - I connected modem via USB to computer as image in this document shows:http://rfdesign.com.au/downloads/RFD900%20DataSheet.pdf
    - Another modem is connected to APM using default cable
    - Both modems has solid green and air modem has blinking red
    - RFD900 modem tool gives this message when I tried read settings:
    -----Loading settings to port COM1-----
    Connecting to COM1
    Sending +++
    Sending ATI5
    Reconnecting using default Baud Rate
    Sending +++
    Sending ATI5
    Failed to load settings. Please try again
    - Mission planner com1 at 57600 timed out and gave message: No heartbeat packets received
    - Mission planner AUTO at 57600 timed out
    - Windows 7 64bit device manager shows only COM1 when AOM is not connected via USB and modem is connected to computer
    I have perhaps some very basic mistake here because I haven't used any modem before.
    Henri
  • Hello!,
    The RFD900 has the same pin sequence available on the bottom row of pins as on the 3DR radio.
    http://rfdesign.com.au/images/RFD900_Physical_pins.JPG
    http://http://code.google.com/p/ardupilot-mega/wiki/APM13DRadio -- shows the connection to a 3DR.
    An off the shelf cable is available here which will directly connect the APM1/2 to an RFD900 :
    https://store.diydrones.com/Xbee_Oil_Pan_connector_cable_p/kt-telem...
    Let us know if you need more information.
