  • I have tried this method....  Go to terminal and the unit just keeps popping up with question marks and telling me it needs a pre arm fix
  • On mission planner, go to "Config / Tuning", then to "Full Parameter List". On the right side there's a button called "Reset to Default"
  • Thanks guys
    Enter terminal, type 'setup' 'reset'
    It also recommended that you then go into setup and type 'erase' to reformat the dataflash
    See http://code.google.com/p/arducopter/wiki/AC2_CLI
  • Did you read wiki pages??
    ...there are a button in APM, to reset it.
  • I think that the Terminal tab using SETUP then Erase and Reset will do that.
    Before you click the Terminal tab button be sure and set the correct USB port number and 115200. You don’t need to connect first. When you click the terminal button it will automatically connect. Also make sure that you have the latest Mission Planner.
