How to test a powerfull frame
As i feel a bit dangerous to test my frame with the hand grip test because there is quite a lot of power on it, (6 times 350W motors, giving more than 10 Kg total thrust) i ask myself what would be another safer method to test it.
The hand grip test is dangerous because i have no easy way to firmly grip the frame from behind. And the quite heavy weight does not help (about 4 Kg).
Are there any trainer mounts systems usable for multicopters ?
I ever successfully passed a first ground test with the multi firmly linked to the ground. I could verify that all motors and propellers are correctly mounted, and that thrust is going to the right direction for each stick movement.
Thanks for helping,
