QuadX, APM2.0, Arducopter 2.8.1
I did calibrate radio and ESC.
Then I did level the quad in Configuration / Level (using also spirits level), HUD becomes horizontal.
When arm the quad (0:12min), HUD starts to tilt on right, without any motor (throttle) action or moving quad, see video below at min 0:12 and 1:27.
When disarmed, HUD is back as horizontal.
When armed again (1:27min), HUD is tilting again on right, same direction.
Is that normal, since I did level the quad and then I did not touch the quad and not motors action?
Thanks. Chris
Can someone help me to find out if is normal to see the HUD tilting by itself after Armed command, without any touch on quad? APM2.0, Arducopter 2.8.1.
I just want to eliminate the causes to see if my APM2.0 is still OK or not.
Steps I did (without any throttle percentage):
-Connect in MP with APM2.0
-Level quadX in Configuration tab, HUD become horizontal, quad is leveled with spirits level
-Armed the APM2 (yaw right control), 0zero throttle
-HUD is tilting to the right 15 deg, without any touch... <<<-----Is that normal?
-Disarmed, HUD become horizontal again.
-Armed again, HUD tilt again same direction... what is wrong here?
