  • Admin
    @Jake,
    Try here
    TCII AVD
    • I need apm tricopter 3.1.5
      I'm not sure out of all those dates which ones are stable versions or are they all stable?http://www.rcgroups.com/forums/showatt.php?attachmentid=5401256&amp...
      http://www.rcgroups.com/forums/showatt.php?attachmentid=5401256&stc=1
      • In that case you need the "APM1-tri", "APM2-tri", "PX4-tri" - depending on which APM board you are running.
        Unfortunately you will have to do a bit of trawling to find the 3.1.5 stable version. Look at the "git-version.txt" in each folder for the version details.
    • Thank you sir I had found that but the tricopter hex is not labeled or im unsure how to read the file system not sure how its organized
      • I'm not too sure what you mean by "tricopter hex" - do you mean a "Y6" configuration?
        Each dated folder in aforementioned link contains a date/time of the build and then the build configuration.
        For example this folder: http://firmware.diydrones.com/Copter/2013-09/2013-09-06-12:09/PX4-y6/ contains the PX4 build for the Y6 copter, that was built on 6th September 2013. By looking at the "git-version.txt" it will tell you that it was the V3.1-dev version.
